Nodegraph multiple Outputs and Animation
Hesekiel2517
Hey Paul,
i have an animated Environment (.exr Sequence) which is connected via a nodegraph to the environment colour. In the 3.6 version of the Plugin this works flawless. The 3.7 version loads the right frame at first but then jumps to frame 1 (i attached a video). The exported Ocs file works well though. Also plugging the animated Texture in a (for example) slot of a Material works.
Also in Octane you can create multiple Nodegraph Outputs. Modo seems to be limited by one output. When I add another output i get an error and can't edit the nodegraph anymore.
Do you know a solution to this?
Animated_Environment.zip
(21.66 MiB) Downloaded 172 times
Return to “Foundry Modo”
