OctaneRender® for Maya® 3.06.4 - 11.10[ STABLE ]
BK
Maya® Version Requirements
This release will work with Maya® Versions 2016, 2016.5, 2017 and 2018 64-bit on MS Windows operating systems, 2016, 2016.5, 2017 and 2018 64-bit on Linux operating systems, and 2016, 2016.5, 2017 and 2018 64-bit on OSX operating systems (including and above 10.9).
You cannot purchase and use only the Maya plugin and use it without also owning an activated copy of Octane Render™ Standalone on your machine.
For network slave and daemon please download the Standalone installer here:
viewtopic.php?f=24&t=61815
  • Octane Daylight value set to default
Please note that the motion blur improvement would be embedded on the refactored version to be released in the near future
Windows
DOWNLOAD
OctaneRender for Maya11.10
OctaneRender for Maya DEMO 11.10
Linux
Installation:
- Just run the installer to see its command line keys.
DOWNLOAD
OctaneRender for Maya - 11.10 Linux
OctaneRender for Maya DEMO - 11.10 Linux
OSX
Installation:
- Just run the auto installer file.
DOWNLOAD
OctaneRender for Maya - 11.10 OSX
OctaneRender for Maya DEMO - 11.10 OSX
Kind Regards
bk3d
itsallgoode9
Is this compatible with 2018.1 or only 2018
yfripp
I've been using it with 2018.1 and haven't encountered any unexpected errors.
Windows 10 | i7 4770K | Titan X | 32gb
BK
itsallgoode9 wrote:Is this compatible with 2018.1 or only 2018
hi, itsallgoode9,
yes, this is compatible with 2018.1.
Kind Regards
bk3d
itsallgoode9
hi, itsallgoode9,
awesome thanks! just wanted to check before i downloaded that maya update.
BK
yfripp wrote:I've been using it with 2018.1 and haven't encountered any unexpected errors.
Hi, yfripp,
Thanks for your feedback :)
Kind Regards
bk3d
BK
itsallgoode9 wrote:
hi, itsallgoode9,
Cool.. Thank you !!
Kind Regards
bk3d
renmaxhb
I comeback to maya 2015 from 2017,add surport 2015 please :roll:
BK
renmaxhb wrote:I comeback to maya 2015 from 2017,add surport 2015 please :roll:
Hi, Renma,
Here is the link to our last stable release [ viewtopic.php?f=109&t=62064 ] which supports Maya 2015.
They both using same engine version 3.06.4 and the future releases will work only on Maya which is 2016, 2016.5, 2017 and 2018.
Kind Regards
bk3d
renmaxhb
Hi, Renma,
BK,thanks :lol:
Locked
