Navigation
JNDesign
Hi Paul
Thanks for all your hard work with Revit / Octane intergration.
Could I ask if there is a road map for better tools for Navigation / Paper model etc like Enscape?
Whilst I love the way Enscape make navigation extremely easy (like walk thru, change render engine to be paper look model etc) it definitely doesn't match up to Octane's render output.
Would love you at least consider..........
many many thanks in adfvance
Hi - I have not seen the Enscape plugin, so not really sure what you are specifically requesting here.
Marvez
thanks for the feed back I use Revit and I also love Octane - I wondered about enscape and was on the fence
Paul see ... https://enscape3d.com/
I7 5820K 16MB RAM SSD850PRO GTX 970/780
JNDesign
Enscape has nothing over Octane engine however their navigation tools are superior
I tried Enscape but found it lacking Octane's speed and high quality / fidelity output
Someone said a while ago that Octane is like formula 1 ie as good as it gets :)
Paul if you can input some of the tricks like Enscape navigation tool, it will make your awesome plugin supa awesome
cant wait.....
Return to “Autodesk Revit”
