Loading Materials from Scene - Problem AC21 & 3.7.0.76
BfPuVAK
Hi Paul,
I've got a problem with AC20 projects opened in AC21 and running the 3.7.0.76 (64 bit) plugin.
It stucks while "Loading Materials from Scene. Please wait..." (even small scenes / after ~30min no progress)
After reinstalling 3.6.4.74: same problem.
Ditn't work for a while with AC21, so I can't tell since when it doesn't work (anymore).
By the way: AC20 and 3.7.0.76 - no problems, and: new project started in AC21, no problems, too.
Any idea?
Greetings,
Artur
Win 10 Pro 64bit / Intel i7-6700 @ 4.0 GHz / RAM 32GB
2 x Nvidia GeForce GTX 980M 8GB (+ sometimes a GTX 970)
Archicad 21 4022 GER Full + Octane Render !
https://www.youtube.com/watch?v=7l7SefSWV98
http://www.youtube.com/user/BfPuVAK/videos
s3d-weyrauch
Same Problem. PLN Update from AC20 to AC21 doesn´t work. I can´t use our template as well...
I haven´t installed the new Test-Version for AC21, I have only the 3.6.4.74.
David
BIM team leader
Win 10 | ArchiCAD GER 23-24 | Octane Plugin for ArchiCAD
13 Licenses | Network Render over 12 graphic cards
Can you try with 3.7.0.76 and AC21 pls?
BfPuVAK
Well, 3.7.0.76 was that first one, I remarekd, that it doesn't work ;)
Can you please send me a scene which exhibits this problem, and I will take a closer look.
s3d-weyrauch
https://drive.google.com/open?id=0B7zjb ... FRIM2JpSkE
Here is our template as a PLA. I migrate it from version to version. Every ArchiCAD-material has octane-settings, and there are some example-scenes as well.
It hangs on loading Materials.
ArchiCAD 21 Build 4022
Octane Standalone 3.06.4
OctaneRender_for_ArchiCAD21_3_6_4_74_64bit
David
BIM team leader
Hi - that appears to be a bug in the ArchiCAD 21 SDK related to the processing of materials with names that contain non-standard characters. I have contacted Graphisoft to get some direction on the problem. In the meantime, pls revert to ArchiCAD 20 if you with to use the Octane plugin.
