C4D to ORC problem
Discussion forum for OctaneRender Cloud
gergo_szabo22
Hello,
I am trying to set up a render to the Cloud from C4D, but i get a few problems. I have read the ORC FAQ's and tried to set up everything according to them. The problems I get:
- When I export from the live viewer to an animated package, it exports my scene with 47 frames with 24 fps, however, my render settings in C4D are set to 60 frames with 30 fps. The resolution and the sample size per frame are exported correctly however. Uploading the job to ORC still gives me a 47 frame long scene.
- The second, and bigger problem is, that I have a couple animated materials in my scene (the blackbody emission intensity is animated in 3 materials, and thats all), which are not showing up in the standalone. I checked all frames and the keyed C4D values are static in the standalone.
What could be the problem?
I have C4D R18 + plugin 2.24.2 + standalone 2.26.1
(Sorry if I the questions are already asked somewhere in the forums, or if i'm missing something blatant, i'm kinda noob to ORC, and even standalone itself, I only used the plugin so far :oops: )
It's better on V3 versions of plugin. There's no support for older versions on improving the functionalities.
gergo_szabo22
Ok, thanks! Will upgrade my license to V3 and try again! :)
Return to “OctaneRender Cloud”
