Missing Textures feature
fabrizio_s
when I change one texture folder Octane "says" to me which texture is missing and it is fast to reassign the right folder. The problem is if I change many folders. It is very time-consuming to assign the right folder to every texture.
Is it possible to put a simple feature like "search in folder and subfolders"? Connecter (a plugin for 3ds max) does it and it is even possible to specify the favorite paths or search in the last used paths. And...I am not sure but I think Maxwell does it too (folder and subfolders).
This features could save a lot of time especially in big projects.
bye
fabrizio
The plugin should search all sub-folders of the current search folder. If you are certain this is not working for you, pls let me know and I will investigate.
fabrizio_s
Hi Paul,
you are right. It works fine.
It was a problem with the partition of my HDD.
thanks a lot
bye
Return to “Rhinoceros 3D”
