Not saving layer passes - R19
Jerpan
Hi!
Cinema (or octane) seems to not want to save my multi-passes. It creates all the different folders for it, it comes up in the Pictureviewer so that I can solo them, but they won't save..
As I first used Takes I thought that it might be the problem but it was not. We tried the scene on R18 on 3.06.4 and it worked.
Tried then to install that version on R19 but cinema just crashes when opening any file.
Win10
4x GTX 1080 Ti
64GB
385.41
3.07 test4
Cinema R19
Delphis
I had same issue.
Also noticed when rendering takes, R19 finishes rendering at random frames, for example sequence is set to range 0-125, rendering finishes at 61, or at 1.
If I try to render it further, it renders black like no scene is there!?!?
If I restart R19, it renders but again it stops at random time saying rendering finished.
R18 works fine.
Hi, Why don't you send a sample scene to figure it?
