3.07-R1 [Alpha]
Moderator: aoktar
hellguy
OctaneVR for After Effects 3.07-R1 Alpha
You can download via the customer downloads area here:
https://render.otoy.com/account/downloa ... LL&ver=ALL
Current limitations / Known issues:
  • If you sign in with an account with no available subscriptions, the application will crash. In order to avert this crash, and sign in with a OctaneVR subscribed user, you need to delete the files in `%APPDATA%\OctaneRender\` (DO NOT DELETE any of the sub-folders)
  • Objects accept only .orbx files.
  • Under and Octane Render Effect, only object-1 and object-2 are supported in the Node Graph Edit.
  • The alpha test version is built against SDK 3.07, however, some 3.07 features are not yet implemented in the plugin.
If you encounter any issues using the plugin, please contact us at [email protected]
