wrinkles map ?
visionmaster2
Hello,
is there a way to make wrinkles map with octane in 3dsmax ? like this old one : https://www.youtube.com/watch?v=Y8rFxe9Svfg
the 3dsmax morpher mat dont work with octane.
for the moment i use dense mesh...but its not the solution https://www.youtube.com/watch?v=gae1-9KZkXs&t=11s
thank you
M.°
paride4331
Hi visionmaster2,
I personally do not know the limits that prevent integration between 3dsMax maps and materials with external rendering engines.
A workaround, not adaptable to any situation, could be using an Octane material mix node and animate amount in the 3dsMax timeline during your morphing phase.
Regards
Paride
visionmaster2
Thank you Paride,
it is not possible to animate by hand such mocap file (150 blendshapes/morph) and the wrinkles map transition must be an automatic process to have the correct /acurate animation.
With Octane we can't have wrinkle map and blood pressure map. That's the only render enginee that don't have this possibilities.
that's a pain in the ass for me, but for the cartoon series we have in preproduction, we will use another render engine.
sorry for my bad english
Thank you
M.°
paride4331
Hi visionmaster2,
I see. can I ask you in your opinion what is the best rendering engine for this workflow?
Regards
Paride
visionmaster2
Hi Paride,
i think Vray is great for that http://lesterbanks.com/2015/10/wrinkle- ... lacements/
the process is almost similar in Arnold or mental ray and reeltime.
another exemple here : https://www.youtube.com/watch?v=tEundsR3TJ4
regards
M.°
paride4331
Hi visionmaster2,
thanks, I'll investigate this to figure out how to improve workflows like these using Octane Render.
Regards
Paride
visionmaster2
Thank you Paride !!
M.°
nildoe
@Paride
Any news on this? I also really need to have animated wrinkles using octane! :(
Corei7, 6x GTX1070 (2 Inside and 4 in a CUBIX Xpander), 32GB Ram, Win10 64Bit Home, 3dsMax2017 64Bit, Octane for max 3 and LOVING IT!!!!
MSI GT72S 6QE Dominator Pro G win10Home, gtx 980m.
paride4331
maybe a workaround could be exporting blendshapes to .abc, baking Wrinkle Maps sequence, then use those in displacement slot.
Regards
Paride
nildoe
sounds like it could work..will try...
thanks for the sugestion
Return to “Autodesk 3Ds Max”
