Environment List Problem
Moderator: BK
atack12
Hey, I'm having a very annoying problem from quite a long time, is there any option to clear the whole environment list? When I want to change for example "Default HDR Texture" to "No Environment" I have to scroll for about a minute...
Hi - deleting the C:\Users\[username]\OctaneRender\Data\OctaneRender_presets.* should resolve this.
If not, delete that entire folder. Be aware if you do this your current Preferences settings will return to defaults.
DrHemulen
I'm having a similar issue with rendersettings, but also get a lot of the environment ones. Sometimes it seems like it's only tied to a specific file. When opening DAZ the lists look fine. When I then load a saved file, these crazy lists show up. Do you think the plugin may be saving duplicates every time the user saves the scene?
I think it is a little drastic having to kill all your preferences (including material presets) every time this happens.
GTX 780, 6 gigs of VRAM - Win 7 Home Premium 64 bits
Hi - try loading the scene with the Preferences->Don't Load Environments unticked?
DrHemulen
Thanks, I didn't know of those settings. That seems to work, both for rendersettings and environment. It of course also deletes any settings you'd want to keep.
A workaround could be to add the settings you want to keep from the crazy list to your presets, as these ARE loaded with the option ticked :)
Return to “DAZ Studio”
