Textured Lighting UV Maps
Moderator: BK
Hydra
Hey.. I'm having issues with textured lights. In some cases the designer has the UV facing the opposite direction. i.e. inside a SciFi Panel. Is there any way to get light to emit from the other side?
Intel i7-4790K, Asus Z97-A, Corsair 32GB DDR3 1866MHz CL9, 2XAsus STRIX GTX980 DirectCU II OC 4GB, 4XSamsung 840 EVO Raid 10, Win 7 x64 Pro.
With Octane 3.07 you should be able to set the emitter material to double sided - which may help in the situation you describe.
Hydra
face_off wrote:With Octane 3.07 you should be able to set the emitter material to double sided - which may help in the situation you describe.
Will that possibly be an option in the Daz plug in?
Yes, this is in the current test build of the DAZStudio plugin.
Return to “DAZ Studio”
