Hi there Octaner´s,
I have a littel issue and couldn´t find any post about the problem you can see in the subject..... Just the other way around!
If I render it out - it works as it should, but it´s slow down my workflow like in good old day with the physical renderer in Cinema.
Maybe someone have the same problem and found already a solution?!
cheers and thanks for reading!
dual xeon x5660, 24gb ram, win7, cd4 17, octane 3.06.2
2x gtx 1080
2x gtx 980ti
2x gtx 1070
no motion blur in live viewer - C4D
what's problem?
what's problem?
na ja, the problem is, that the live viewer don´t show/indicate the activated motion blur. Just the camera motion blur is working fine.aoktar wrote:Hi,
what's problem?
however, the motion blur is working, when I render it out, but I need it in the live viewer!
Every tutorial I watched it works normally in the live viewer.... but not here!
Read this old notes: https://docs.otoy.com/Cinema4DH/C4DPlug ... onBlur.htm
You should be more clear to describe issue. When you start a render in LV it will show motionblur. There may be a spesific case and you missed somethings in difference's logics of LV vs. PV rendering.
