PT leaves tiny dots in final renders?
sahhar
Hello again!
When I use PT render mode I end up getting all these extra tiny dots throughout the render that look like clipped light values.
This is negative side effect is greatly amplified when I use blackbody emitters, However it can end up in any scene.
Any ideas what's causing the issue or how to fix it?
Thank you :)
https://imgur.com/a/Y92zR
Here is a link to a render where the dots showed up, enlarging it will help you see the detail
Hi sahhar,
unfortunately, I cannot see well the issue in the attached image.
Do you mind to use Upload attachment button next time?
Thanks.
Anyway, maybe you are referring to this known issue:
viewtopic.php?f=30&t=56386&start=10#p289812
