3.07 LocalDB not working
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
rifat
Hey,
I realize on octane c4d 3.07 localDB is not working.
simply not showing anything I saved in the preview and when I flip through folders, it crashes my c4d.
(tried reset directory, and all the .orbx files are in the folder.)
windows 10
2 gtx 1080
16gb ram
Nvidia driver version 385.41
octane both standalone and plugin 3.07 Test a3
C4d R18 18.041
Hi rifat,
thanks for the report.
It seems that there is an issue with refreshing the material list.
Please, try this steps:
Open LocalDB
Drag a new material for saving it
Close the LocalDB window
Reopen the LocalDB window, and the material should be correctly saved.
rifat
bepeg4d wrote: Open LocalDB
Hey bepeg4d
Thanks for the super quick reply and help.
I tested it just tested it.
My c4d crashed straight away when I drag any octane material in the window.
Tried few times still crashes
If I open LiveDB window and close it straight away it also crashes C4d.
Also tried to relocate entire library to C: drive Don't work either.
Cheers
rifat
One extra information.
I switch back to 3.06.2 it start working again :)
Hope that helps
no issues with LocalDB to report here under Win, the refresh issue is only under Mac.
Do you mind to try another time, but without moving anything around?
I mean, just update another time with the following version, and see if the issue persist?
https://render.otoy.com/customerdownloa ... 3a-win.zip
rifat
Hey beppe,
Just tested it.
If I click on "LocalDB" It actually previews and it's usable. ----------Works!
But it does not work under this situation. which is how I setup my library. ------------- do NOT work
LocalDB
-- Brick
-- Car Paint
any of those folders do not have a preview (But can see previews of materials in 3.06 and able to use them).
It crashes once I press few times on any of the names too many times e.g. --Brick
Help this make sense. LocalDB works, but subfolders won't.
Cheers
Return to “Bug Reports”
