Hello,
I have multiple bugs with octane, for example rendering, there are polygons that are 100% black or the light illuminates the other side of the face (wall).
Otherwise, when I modified my file of the 3D object and I re-import, octane does not want to refresh the scene, therefore obliged every time to disconnect and reconnect for it to work.
For material octane, sometimes it removes the parameters I just made.
Thank you.
Sorry for my bad English.
Olivier
From multiple bug
Moderator: ChrisHekman
Hi Oliver,
no need to apologize, I was able to understand your message just fine.
Can you provide me with a screenshot of what you are referring to?I have multiple bugs with octane, for example rendering, there are polygons that are 100% black or the light illuminates the other side of the face (wall).
Yes, this is definitely an issue. Thank you for bringing it to my attention.Otherwise, when I modified my file of the 3D object and I re-import, octane does not want to refresh the scene, therefore obliged every time to disconnect and reconnect for it to work.
Are you using an Octane PBR override shader in Unity, or are you modifying the standard/standard (specular) shaders? The Unity shaders will be reset to their default parameter configuration in the Octane graph. If you have this problem with an Octane PBR override shader, that's an issue we'd have to look into.For material octane, sometimes it removes the parameters I just made.
- Rick
My project is under construction, but I test Octane in advance to try
The light that crosses the mesh for no reason
For this image, I have polygons 100% black
These bugs, I have a little everywhere in my building.
I use Unity texture material without texture and I also tested with your Octane material but it always does the same problem.
I could not provide my project but I put you another 3D object that has the same problem (as shown in the image above).
Here is the link to download : https://drive.google.com/open?id=0B_rbw ... GJPYTdvN2c
I hope this is not a problem ?
Thank you.
