ADDING UVW MAPPING Crashes RENDER WINDOW
When running a LIVE OCTANE RENDER WINDOW, and you go to add a UVW MAP, it crashes the entire 3dsmax session immediately. It happens consistently every since time. If you remember to pause the live update and then add it, you can get away with it. PLEASE fix this, it is driving me crazy.
C. RAM Capacity (i.e. 6 GB)
- paride4331
Hi richardyarlett,
I tried your issue but everything seems to work fine.
Could you kindly share a scene (even in PM) where your issue happens by adding UVW MAP?
Regards
Paride
Regards
Paride
- richardyarlett
This is still an issue. I just updated to the very latest NVIDIA drivers and 3dsmax 2018 update 3 and Octane last version.
No change. Any attempt to ADD UVW to any scene, even just an empty scene with ONE object, immediately takes down the entire 3dsmax session hard. Can you please look into this asap. It is very frustrating.
It only happens with LIVE VIEWER OPEN, and only if it is running. If you PAUSE the LIVE VIEWER, then add the UVW MAP, and then unpause it, it is fine.
- paride4331
