Stand alone texture animation box
gah5118
It would be great to have the corresponding frame number (based off of the chosen start frame from the selection below) to the left of the selected file. Many times I have 10 frames using the same file, then a different for a couple of times, and so on. It can take up a bit of time to double check over things to be sure the appropriate amounts are set.
On a side note, if you accidentally select to open a image rather than clicking the film strip, it will clear out the list. It would be great to see a solution around this.
Windows 8.1 | i7 950 | GTX 780ti | 24gb ddr3
