.exr compression via the modo plugin
TheImageFaculty
Hi Guys,
I see that in standlone there are compression options when you save out an .exr via batch. As far as I can tell there is no way to access the same options in modo.
What is the default compression type used by the modo plugin when saving out an .exr?
D
The Image Faculty ApS
https://theimagefaculty.com
ZIP (lossless).
Return to “Foundry Modo”
