Motion blur with a spline wrap
DannoKaBlammo
I have an object that I'm animating along a spline using the spline wrap modifier, keyframing its offset value so that it travels down the spline. However, even with the Octane object tag directly on the object, I can't get Octane to render the object with any motion blur. I am able to render motion blur only if I animate the object without using the spline wrap as the reason it's moving. Is there a workaround for this situation? Thanks.
Hi DannoKaBlammo,
screenshots, or even better example scenes, are crucial to better understand the specific issue, and have the correct answer.
I'm guessing, maybe you need to change the motion blur to Transform/Vertex in the Object tag of the moving mesh.
DannoKaBlammo
Thanks, bepeg4d! That was exactly it.
