User custom shaders bug is...
Moderator: ChrisHekman
adamnerva
the biggest issue with the Octane plugin for Unity right now. I am building out a render test scene, but every time I come back to it, all of my custom shaders are wiped.
And for me, the second biggest issue would be poor conversion of the Unity standard shader (no tiling, no detail textures, no gloss maps, etc), and so custom user shaders are an absolute necessity for every surface, not just special cases.
Goldorak
adamnerva wrote:the biggest issue with the Octane plugin for Unity right now. I am building out a render test scene, but every time I come back to it, all of my custom shaders are wiped.
Good feedback. Converting standard shaders (or standard specular shaders) should work with detail textures (this specifically added in Octane to handle Unity assets). Gloss map is just an inverse roughness map and this too should work. We'll look into both of these issues ourselves, but any specific scene data you could share might help isolate what is going on more quickly.
Custom shaders created in Unity are still a WIP as we figure out where this goes in the spectrum from std. Unity material auto-conversion -> pure ORBX material importing. Even so, anything we expose as values the Unity Editor panels should work, so if that's broken it's a bug we should track and fix ASAP.
adamnerva
Yes, a gloss map is an inverse roughness map. In Unity they are packed into the alpha channel of the metalness map. In Octane for Unity, they don't render at all.
As for the detail maps, only the detail albedo renders, detail normal maps do not render.
As for custom user shaders, they are not saved between octane sessions. They get wiped.
matt87
Agree with OP. Really wanted to try out a recent 360 project I did in Unity. Was very impressed with the Otoy samples, so couldn't wait to try it. Was disappointed pretty quickly:
- No terrain shading
- No speedtree integration
- Tiling broken (no one tested that before release, really?)
- Only Standard Shader supported
- Not really clear how to achieve simple but important effects (atmosphere etc)
Was really interested to see my project rendered in 360 by octane, but if I have to go through the entire scene and switch all my shaders around, then figure out all the problems I'd already solved in the first place (lighting, custom water, terrain shading), then not sure why I would bother? I could just do that in Maya or Max. Don't want to sound harsh, but this really doesn't feel like a integration, more of a bolt on. Understand it is very early days but one of the biggest flaws with this idea is that so many people use custom shaders/solutions for complex problems - water, terrain etc- I really can't see how you guys can "convert" peoples scenes to work with Octane on the fly.
I always hoped the idea behind this would be to add greater visual fidelity to existing Unity scenes, but it actually seems like you'd need to start from scratch with Octane always in mind and make all your decisions based on what would work with it.
ChrisHekman
adamnerva wrote:Yes, a gloss map is an inverse roughness map. In Unity they are packed into the alpha channel of the metalness map. In Octane for Unity, they don't render at all.
I looked into the custom user shader issue. Part of the saving mechanism was removed in the latest T1 sdk. Ill see if we can get it back in asap.
jakzun
"... it actually seems like you'd need to start from scratch with Octane always in mind and make all your decisions based on what would work with it."
i'm cool with that - thanks for the heads up - it needs to be added to the manual/tuts - as well as making it CLEAR you must be online for Octane to work
i'm getting my first renders and i'm wildly excited by the possibilities - tho', 7.5 minutes per frame is rough - i need to do some tweaks, obviously
i salute this effort and i will support them and i am grateful we will one day have this for Unity - and, WORKING
so, i know all your feedback has been invaluable - let us see if if makes a difference
Glader
ChrisHekman wrote: I looked into the custom user shader issue. Part of the saving mechanism was removed in the latest T1 sdk. Ill see if we can get it back in asap.
Any update on this? Pretty important to be able to persist created octane materials between loads.
Goldorak
We're working on this now!
Return to “Unity”
