Xpresso problems
I noticed that objects with custom xpresso user data inside a cloner caused a lot of crashes. Is this a known issue? Current state to object solved the issue, but you lose the parameters. Object was the parametric window from one of the c4d presets libs.
Windows 10 - 64GB RAM - Cinema 4D R20 - RTX 2070 x3
What's crash here? Any more information about it? Could you post a scene or more data to reproduce what you mean?sdanaher wrote:I noticed that objects with custom xpresso user data inside a cloner caused a lot of crashes. Is this a known issue? Current state to object solved the issue, but you lose the parameters. Object was the parametric window from one of the c4d presets libs.
aoktar wrote:What's crash here? Any more information about it? Could you post a scene or more data to reproduce what you mean?sdanaher wrote:I noticed that objects with custom xpresso user data inside a cloner caused a lot of crashes. Is this a known issue? Current state to object solved the issue, but you lose the parameters. Object was the parametric window from one of the c4d presets libs.
OK so not a known issue... I will try to post something after current production is finished.
