X-Particles Motion Blur Tips?
Teddi
Anyone got any tips for getting motion blur with Octane and X-Particles to work?
I've got a scene with a fluid coming out of a pipe and I can't seem to get motion blur to work (only tried Live Viewer window so far).
My X-Particles setup is an emitter, and a skinner and a gravity modifier. (It looks like a thick, gloopy liquid, like unrefined oil).
I've cached the particle system and added Octane object tags to almost everything in scene (progressively, trial and error) and I definitely have the motion blur setup right in my Octane camera.
I've also Googled this and read quite a few forum threads but can't find anything which addresses the problem.
Any ideas?
Cheers.
You have to select "transform/vertex" mode for deformed objects and these have to be having constant vertex amounts. Skinner objects propably will not provide a constant vertex counts.
Teddi
Thanks for the prompt response aoktar.
I tried doing what you suggested and it still doesn't work.
Presume it's a vertex problem as you suggest.
I guess I need to research X-Particles more and find a way of simulating fluids that will create constant vertex amounts, if that's possible.
Cheers.
Teddi wrote:Thanks for the prompt response aoktar.
Cheers.
Propably yes! Another new option is vertex speed option. it will require x,y,z components via vertexmap tags.
See this post for setup. It's a similar question.
viewtopic.php?f=30&t=62420
Teddi
Will try that, thanks again aoktar.
Teddi
I've tried adding a vertex map tag to the skinner object but it won't work, I think because it's not baked geometry?
Anyone know how to do this with X-Particles?
Cheers.
Teddi wrote:I've tried adding a vertex map tag to the skinner object but it won't work, I think because it's not baked geometry?
Cheers.
You'll see that these tags are produced by realflow plugin's itself. You have to find a way to link/transfer correct speed values to these tags. It may not be supported as being in RF plugin.
Teddi
Ah, thanks.
If I could bake the skinner animation mesh into C4D somehow would that work with Octane motion blur?
Teddi wrote:Ah, thanks.
I think no! Maybe export/import as alembic works, but not sure. Because correct values in these tags are critical requirement.
Teddi
This plugin looks like it will do something similar with the X-Particles skinner mesh that Real Flow does with its meshes, I think.
https://nitro4d.com/product/nitrobake2/
This would presumably turn the skinner mesh animation into something with keyframes that Octane would recognise for motion blur?
