Hello to everyone, I'm going to assemble a new PC.
I wanted to ask you an information:
Which chipset for motherboard is the best solution for a PC, oriented to rendering work?
Another thing...AMD o intel processor?
Thanks a lot
New PC
hi there,
If you can, i suggest to wait till the 10th of august; AMD will release threadripper, you could use those 64 pci lanes. (i think 8 are reserved for m.2s etc. but still...).
It's Bleeding edge technology ofc. but very promising. Just wait a couple of weeks if you can. Besides, the prices of gpus are slowly getting back to "normal",
they are still artificially inflated due to cryptocurrency ...
Cheers~!
Cheers~!
ok thanks, but for me the price of AMD processor is very very high!!
and about of Intel chipset, do you have any suggestions?
There are too many variables!!! Intel x299, Intel z270, Intel b250, Intel z170 ecc......
I excluded the series Hxxx, because I understand that it does not allow overclock.
Thanks again
Thanks again
SORRY, MY ENGLISH IS BAD!
2 Xeon quad core E5440_8gb Ram_Nvidia GeForce 2GTX 780ti 3Gb/Nvidia Quadro K2000_Win10 64bit_Octane 3.02_Rhinoceros3D
- Phantom107
Look for a CPU you want, not the chipset. Best one available IMO is the i7 7700K overclocked to 4.9-5.0 GHz. Modeling tools are not multithreaded so then all those cores on AMD and uber-expensive Intel chips are useless. It's better to have a high clock speed single threaded. When you've chosen a CPU then you can look which chipset it uses and then look at boards.
High-end motherboards have a PLX chip which adds a bunch of available PCI-e lanes. Example: http://www.gigabyte.co.nl/Motherboard/G ... -rev-10#kf
That's what I'm doing and then you can sport 4 cards... AND have a high clocked CPU.
The only case you really need a lot of cores is when Octane is compiling the scene, but with hyperthreading and high clock speed it's no issue at all.
Hope that helps
Hope that helps
Developer of tools for Octane:
Phantom Scatter - Phantom Node Link - Phantom Photo Match - Phantom Architecture
- Phantom107
Oh yes... so M.2 does indeed eat PCI-e lanes; personally I'd settle for a 'normal' SSD to be sure it all works! Would be really bad to have problems there
