Daylight Environment in Z-Up projects
vladimirleleiva
Hello,
I do work with Z up axis in Modo and have some issues with Daylight Environment, which appears rotated and when directional light is above -- the scene becomes sunset lid instead of a bright day. Any suggestions on how to fix this without changing project properties back to Y up axis? Here is a screenshot: https://i.imgur.com/DHGG3qF.png
Hi, and sorry for the delay responding to you. The plugin assumes that Y is UP, so you will need to change your project properties if you wish to use the Octane Daylight Environment.
vladimirleleiva
Okay, no problem, I'll figure it out somehow. By the way, your videos are great. Found it very informative, thanks a lot.
Return to “Foundry Modo”
