Adaptive Sampling
Houdini Integrated Plugin
derekhanz
I have a scene with heavy depth of field. There is a lot of the frame which is a flat shaded surface, and a few bright highlights that have Bokeh'd out. There is noise in DOF as expected.
I've tried all of the variations with Adaptive Sampling turned on to help Octane focus just the DOF areas. I see no difference in noise or speed when using this feature. Could you please explain a little how to use it in such a setting?
Thank you
juanjgon
You have all the theory about the adaptive sampling on this post:
viewtopic.php?f=33&t=60014
But if you want to share a sample scene, I could take a look at it here to see what can be done.
Return to “Houdini”
