Maya crash on batch render
generaljanks
Hello, hoping someone has a solution for this.
Rendering within Maya works great in render view, but on launching batch render, Maya starts writing the temp render file for batch render and then crashes. This is a project we did a couple years ago using VRay and it rendered fine.
Scene contains one referenced set model, about 50 fairly simple referenced characters, some of the characters have static (non-dynamic) nHair. There are about 50 Maya render layers. I have tested scene with only 10 Maya render layers and I get the same result, so I don't think that is the problem.
Any suggestions?
Maya 2017 Update 4
BK
Hello Generaljanks,
Any warning/error message before Maya crashes? Please check render log or verbose mode enabled?
Also, which OS are you running Maya?
Kind Regards
bk3d
Return to “Autodesk Maya”
