HDRI rotate inside plugin
nick73
Hello,
I 've done a lot of research but I haven't found a answer yet. Working inside archicad plugin and using an HDRI picture as texture enviroment is it possible to rotate it ?
Hi - the manual explains how to do this. https://docs.otoy.com/ArchiCAD_Plugin_M ... L%7C_____3
nick73
That was fast, thank you.
It works.
For anyone has the same issue, HDRI should be rotated by sphere transformation and not by UV tranform as I did.
s3d-weyrauch
Hi Paul,
I and my colleges find the separation of UV and projection transform not so reasoned.
UV-Transform is always available even if you have another projection. UV-Transform should be under the Projection node.
It would be even better, if UV-Transform was grey, when the projection is not UV.
Best Regards
David
BIM team leader
Win 10 | ArchiCAD GER 23-24 | Octane Plugin for ArchiCAD
13 Licenses | Network Render over 12 graphic cards
Hi David - I agree, however the Image node used for the IBL is a standard Octane Image node, that would usually be UV mapped onto geometry. Perhaps a better option would be to have an Image node which was just for IBL Images used for the Texture of a Texture Environment, which would not have the UV Transform pin. You could submit this to Otoy as a Feature Request if you feel strongly enough about it.
