Hi Paride,
I asked before but noone could help me. Anyway to have Dirt map to be locked in on local element level to one object. For example i have a dirty tire but since it is touching the asphalt dirt also shows up where tire touches the asphalt. If it was on local mesh level only this problem would not happen when other objects are in close proximity
thank you
Dirt map on local mesh level
- paride4331
Hi coilbook,
SDK currently does not include this option..
A workaround is to bake your material with dirt map and reapply it to the wheel.
Regards
Paride
Regards
Paride
