.renderState - simpliest possilbe question... please help
Forum for OctaneRender Lua scripting examples, discussion and support.
tomsawyer
Could someone help me out with a very basic task:
using LUA, I want to know if the current render target has finished rendering (had reached the samples/pixel)
if I do in Script window: print (octane.renderState), it will return "table".
I am new to LUA/octane - forgive my blindness on the subject: is this octane.renderState just a variable/holder for different states? or is this a function that can be called to find the state of current rendering?
I have also tried: octane.renderJobStatus
Sorry again for the very basic level, I have only used maxscript and MEL, I didn't expect to take me so long to retrieve some simple system variables using LUA.
(What I need is a very basic .lua that will be called from a batch line. All this .lua has to do is to check if samples are reached and save the render passes as layered exr.... )
ANY feedback greatly appreciated !
THANKS
Hi tomsawyer,
if I have understood correctly your question, I would go in another direction:
stats = octane.render.getRenderResultStatistics()
print(stats.renderTime, stats.estimatedRenderTime, "\n")
if stats.renderTime ~= stats.estimatedRenderTime then
    print("Rendering")
else
    print("FINISHED")
end
If you search "octane.render.PROPS_RENDER_RESULT_STATISTICS", you can find all the info about the RenderResultStatistics table.
Let me know if this solution works for you.
roeland
If the render was started using octane.render.start, then it is finished when that function call returns.
If you have indeed a script which is called from a batch file, you would have a call to octane.render.start, followed by a call to octane.render.saveRenderPasses (or saveRenderPassesMultiExr).
tomsawyer
Thanks for the hints!
@ Beppe: i have used something similar - I check if the renderState is 4 (rendering)
local function isDone()
    renderIsDone = false
    if (stats.renderState == 4) then renderIsDone = true end
    return renderIsDone
@roeland - thanks: the render is started by a batch file indeed. It worked with the above function, but using octane.render.start makes more sense - I will use this.
I am using octane.render.saveRenderPassesMultiExr
Any idea how to enable tonemapping?
Thanks for help!
Tom
roeland
The values of .renderState are constants in the octane.renderState enumeration, and 4 is the value of octane.renderState.FINISHED.
Saving HDR images with tonemapping is a bit unusual, but it can be done by setting the last parameter of that function to true. But if you want to do any meaningful post-processing with the render passes you'll probably need the images without tonemapping applied.
-Roeland
Return to “Lua Scripting”
