Maya crashes/hangs on render
jotreyes
Hi everyone,
I just purchased a subscription to OctaneVR and installed the Maya plugin. I'm testing it out and unfortunately have run into a big problem. When I go to hit Render, Maya freezes and becomes unresponsive. The IPR render works great. The standalone renderer works great. I just can't hit render or use the batch renderer.
If this helps, I tried uninstalling Maya and the plugin and then reinstalled everything (tried multiple versions). I managed to get a SINGLE render of a sphere with a diffuse texture out, but when I tried it again, it froze and could not get it to happen again unless i uninstalled and reinstalled everything. Even then, it would only work once before the issue came back, and it would not work everytime I reinstalled.
This issue happens regardless of the scene. For example, I can't even render a blank scene.
I'm on :
Mac OS 10.12.5
Maya 2017 (tried with update pack 1-4)
OctaneVR 3.06.4 for Maya
NVidia Driver 378.05.05.15f01
CUDA 8.0.83
TitanXp (pascal)
jotreyes
Just an update, I swapped out the TitanXp card with a 1080Ti and I'm still having the same issues. Again IPR and standalone work fine. I'm not sure what to try next.
BK
hi jotreyes,
we have just replied through our helpdesk.
Kind Regards
bk3d
Return to “Autodesk Maya”
