Strange error
mikefrisk
I have a strange error with lightwave and octane. Whenever I enable octane, lightwave.exe prompts "no disk in drive". This also happens when opening an old project using octane.
This is a new build and i've basically copied my old lightwave folder over for configs/plugins etc, so i'm sure it's something I can fix if I just reinstall and copy over my old folder more meticulously, but I don't want to. I'm hoping there is an easier solution.
juanjgon
Sorry, but I've not seen this behavior before. The problem can be indeed something related to the config files. Perhaps you should try to delete the "LWOctane.cfg" file to see if this helps.
Return to “Lightwave 3D”
