Hello,
How does Octane interpret mesh types for linked objects? Is the mesh type inherited from the lybrary file? (obviously there is no way to set mesh type for linked objects as they are just empties)
I have a scene with a hair system that is scatterring a group of linked objects across a plane. In the lybrary file, the objects are set to the "scatter" mesh type, but I have the feeling that doesn't carry over to the scene file.
I hope my description makes sense.
Hristo
Mesh type for linked data (Particle/Hair systems)
- DigiChuckle
- Contact:
Win10 Pro | Z620 | 2x 8 core Xeon 2.2 Ghz | 64 GB ram | Quadro K4000 + GTX 1060
- DigiChuckle
- Contact:
...nobody? :S Anything?
In my tests the mesh type seems to carry through the linked file. If you populate your scene with a lot of linked particles, override the scene's mesh types to Global, it takes a lot longer to compile before render and the memory usage is higher, while there is no effect on compilation times if the override is instead set to scattered or "as is".
MacOS Sierra 10.12.3 - GTX 970 + GTX 780 Ti - 16 GB RAM - Nvidia Driver: 367.15.10.35f01 - Octane Blender 3.05.3 - 11.23 - Blender 2.78a
- DigiChuckle
- Contact:
Thanks, zukan! I finally tested it myself, too, and indeed it does carry through.
I also tried that with "nested" hair particles. That is, a hair system which scatters a group of meshes, which meshes carry another hair system. Here it is:
The grass is a group of meshes scattered across a plain by a hair system, the "fox tail" of the grass has another hair system on it. All that is linked. Seems to work fine.
