I bought the 'Material Pack for Octane Renderer' from Pixel Lab a while ago but sadly all the glass materials in that are poorly converted and have physically impossible refractive indexes so look awful (I got a refund). The live material selection are usually low res and havent had much luck making one myself unfortunately. So would be good if I had a decent one that I could use as a starting point which I can then tweak to get the desired look.
Also, how do you tell Octane that it is a solid block of glass? For example if I made a cube and applied a glass material to it, then will it treat it as a solid block of glass or just a 'hollow' cube with glass around the edge?
Cheers
As an aside, does anyone know where I can buy/download any high quality material packs for Octane for C4D? I know its a bit lazy, but they are a good starting point!
