dust material?
Sigurdf
Hello,
I'm trying to create a dust material effect similar to this (from C4d):
Can't figure how to recreate the effect in the Maya plugin. Anyone has a clue?
Thanks in advance,
Sigge
blackshore
Normally a light gray diffuse shader, IOR 1.53 should do the trick with a mix shader.
Mask as needed.
Not sure why this would be a problem within the maya plug?
Jolbertoquini
Hi Sigurdf,
I can see in the image they are using a sinewave texture, this for me you need a uv on the proper way but if you have any obejct will not work so well. As you can see the little wood mannequin on C4D is not looking like dust because is always from the top like "snow"
May advise is mix the gold shader (glossy ) and a middle gray diffuse and in amount of mix shader use a color correction node and this one plug a falloff node change the mode to "Normal vs. vector 180deg" this give you a mask based on the y axis of any object. the play with the settings "Falloff skew factor" and use the color correction to contrast the mask to get sharper transictions...
You can add a float texture at the brightness on the colorcorrection node to drive the dust so is not flat :) use a triplannar so is no UV need :)
here a setup:
JO
Shader_dust.rar
Shader network
(2.83 KiB) Downloaded 342 times
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
Jolbertoquini
Lil Update with preview! ^^
JO
Shader_dust_v02.rar
Maya shader with Texture
(1.32 MiB) Downloaded 380 times
Preview
Preview
Return to “Autodesk Maya”
