Compositing tag Cinema 4d
hue_low
Hello
I've encountered a problem with compositing tag in Cinema 4d. I have 2 objects in the scene, one has a glass surface, so the second object is reflected in it, I don't need this to happen,
I tried using a "compositing tag" with "seen by reflection" turned off, but Octane seems to ignore it.
Is there a workaround to this problem?
Hi hue_low,
the c4d compositing tag is not supported.
You can have some basic options by using the Octane object tag, but not the possibility to hide reflection.
Probably the faster way is to use the Render Layer Passes workflow.
Happy rendering,
