ORTHOGRAPHIC PLAN?!
aaron44
Hi all - loving the plugin, working well on the 1080
Am having issues generating an orthogonal plan view - have reviewed other posts, which talk enabling the orthogonal view via the plugin, then adjusting the scale pin.
my issues are
- I can't find the scale pin
- I've read the scale pin is potentially the FOV ( the FOV in the plugin says to adjust the view in archicad )
I adjust the view in archicad, but have to be an insane distance away from the object, which then only partially renders ( on the side of the view port )
So there's definitly something I'm missing relative to the fov / scale situation here.
Any help would be huge!
AARON
OS X Yosemite | 3.5Ghz i7 8GB | Nvidia 780 4GB |
Hi - you are right - the Scale is no longer displayed in the Settings tree, and the FOV is locked. I will fix this in the next release. In the meantime, export the scene to OCS or ORBX and then load into Octane Standalone to adjust the camera settings when Orthographic is ON.
