OctaneRender® for Maya® 3.06.2 - 11.6[OBSOLETE]
BK
Maya® Version Requirements
This release will work with Maya® Versions 2015, 2016, 2016.5 and 2017 64-bit on MS Windows operating systems, 2015, 2016, 2016.5 and 2017 64-bit on Linux operating systems, and 2016, 2016.5 and 2017 64-bit on OSX operating systems (including and above 10.9).
You cannot purchase and use only the Maya plugin and use it without also owning an activated copy of Octane Render™ Standalone on your machine.
For network slave and daemon please download the Standalone installer here:
viewtopic.php?f=24&t=61539
  • Urgent fix on Maya freeze
  • Fixed Octane light's "power" animation issue on batch rendering
Bug fixed for:
Renmaxhb & Cyrillweiss
Windows
DOWNLOAD
OctaneRender for Maya11.6
OctaneRender for Maya DEMO 11.6
Linux
Installation:
- Just run the installer to see its command line keys.
DOWNLOAD
OctaneRender for Maya - 11.6 Linux
OctaneRender for Maya DEMO - 11.6 Linux
OSX
Installation:
- Just run the auto installer file.
DOWNLOAD
OctaneRender for Maya - 11.6OSX
OctaneRender for Maya DEMO - 11.6 OSX
Kind Regards
bk3d
sirenesoong
Hi.
with this plugin my Maya freeze when I open shaders in attribute editor or hyppershade with scenes made with previous version of OctaneRender for Maya.
All ok with new scene.
Thanks!
Q6600, 8 GB ram, Geforce480
BK
hi sirenesoong,
would you be please upload a sample scene or describe step by step to reproduce the bug? Cheers
Kind Regards
bk3d
renmaxhb
All is right,
abc,instance copy,reference,octane light power animation....all works well :D
by.octane light animation only at reshape can be render right.
Thanks for your working.
Rikk The Gaijin
This release is completely unusable for me. As soon as I open a scene saved with an older version, and I click on any Octane material, Maya freezes instantly. I tried both Maya 2016 and 2017, both with the same result.
So much for "stable" release... :x
Hi Rikk,
Can you please reinstall this version [3.06.2 - 11.6] and see if it still freezes? We are looking into it again, hope will come up with a solution soon!! Cheers
sirenesoong
Hi BK,
I made this simple scene (a sphere and a plane) with Maya 2017 sp3 with OctaneRender_for_Maya_3.06_-_10.19.
If you open with Maya and OctaneRender_for_Maya_3.06.2_-_11.5 and try to edit material (octaneGlossyMaterial) from attribute editor or Hyppershade Maya freeze!
http://mosaica.eu/test.mb
thanks.
gianca
Trying to render a scene with maya hair will kill maya instantly.
Reverting back to 3.05.3-9.41 fixed this issue.
G
Note:
Maya 2017 update 3
cyrillweiss
Fix worked for me. Thanks BK!
HW01:WIN10x64/X79/i7-3930K/64gb/GPU:1xTitan X, GTX 1080ti, SW:Maya2018/2019, Cinema 4D R20
HW02:WIN10x64/Z370/i7-8700K/64gb/GPU:1xTitan X, GTX 1080ti SW:Maya2018/2019, Cinema 4D R20
etc. ...
BK
sirenesoong wrote:Hi BK,
thanks.
Hi Sirenesoong,
Thank you so much for the sample scene. We were unable to find any freeze issue on our end.
Could you please make sure that you are runningMaya and OctaneRender_for_Maya_3.06.2_-_11.6?
Kind Regards
bk3d
BK
gianca wrote:Trying to render a scene with maya hair will kill maya instantly.
G
Note:
Maya 2017 update 3
hi gianca,
Could you please try to reinstall this v11.6 and let us know how it goes?
Kind Regards
bk3d
