OctaneRender® for Maya® 3.06.2 - 11.5[OBSOLETE]
BK
Maya® Version Requirements
This release will work with Maya® Versions 2015, 2016, 2016.5 and 2017 64-bit on MS Windows operating systems, 2015, 2016, 2016.5 and 2017 64-bit on Linux operating systems, and 2016, 2016.5 and 2017 64-bit on OSX operating systems (including and above 10.9).
You cannot purchase and use only the Maya plugin and use it without also owning an activated copy of Octane Render™ Standalone on your machine.
For network slave and daemon please download the Standalone installer here:
viewtopic.php?f=24&t=61539
  • Implemented New Engine 3.06.2 SDK integrated [ LiveDB crash fixed ]
  • Fixed different render results on duplicate material
  • Minor improvements on MaterialID and ObjectID
Bug fixed for:
viewtopic.php?p=314671#p314671
Windows
DOWNLOAD
OctaneRender for Maya11.5
OctaneRender for Maya DEMO 11.5
Linux
Installation:
- Just run the installer to see its command line keys.
DOWNLOAD
OctaneRender for Maya - 11.5 Linux
OctaneRender for Maya DEMO - 11.5 Linux
OSX
Installation:
- Just run the auto installer file.
DOWNLOAD
OctaneRender for Maya - 11.3 OSX
OctaneRender for Maya DEMO - 11.5 OSX
Kind Regards
bk3d
johan_D
Hello,
Thanks for update,
I done just some quick tests, the displacement look better, but I'v not textures preview on the Maya viewport,
I done test on Maya 2016.5 and 2017 default and 2.0 viewport, I'v got same result, with old and new scenes
It's juste a problème with me or you broke that?
Pc version, Windows 10
Regards
brianbrook
Since this is stable can we get it for subscriptions?
BK
Hi Johan
Thank you so much for the positive feedback :)
We have made massive improvements on Maya viewport since Octane render for Maya 3.06 - 10.21. Now the texture display support on (Directx, OpenGL and Viewport 2.0)
To avoid viewport lagging, Maya texture preview can now be customized as global texture viewport efficiency setting for all materials or on the selected material level.
Please try changing the texture resolution from Octane Render Setting tab and let us know how it went.
2017-05-30 13_04_50-Autodesk Maya 2017 - Not for Resale_ C__Users_bikram.kshetrimayum_Documents_test.png
Kind Regards
bk3d
BK
Hi brianbrook,
The subscription license is now ready to download.
Kind Regards
bk3d
johan_D
Hi BK,
That's work I had don't see this tab,
Txs
itsallgoode9
Does this just use only us the the diffuse texture in viewport or can you choose (say,
I want to see normal or spec in in viewport)? what about if using layered mix materials?
cyrillweiss
Hi BK
when I load a scene with 3.06.2 - 11.5 (which worked with 3.06.1 - 11.3) maya stalls completely. Can't minimize nor close normally, nothing is clickable and in the Task Manager Maya uses 0% CPU. I left it for about 30 minutes and it didn't recover.
Let me know, what you need to analyse this issue.
Best regards
Cyrill
HW01:WIN10x64/X79/i7-3930K/64gb/GPU:1xTitan X, GTX 1080ti, SW:Maya2018/2019, Cinema 4D R20
HW02:WIN10x64/Z370/i7-8700K/64gb/GPU:1xTitan X, GTX 1080ti SW:Maya2018/2019, Cinema 4D R20
etc. ...
renmaxhb
cyrillweiss wrote:Hi BK
Best regards
Cyrill
They are working on it.
BK
itsallgoode9 wrote:Does this just use only us the the diffuse texture in viewport or can you choose (say,
Hi itsallgoode9,
Currently, it is supporting only diffuse texture in the viewport. Perhaps we would consider these features for our future releases.
Kind Regards
bk3d
