Render Viewport, lost 'info' panel ?
vantrum
My floating OctaneRender Viewport generally has three vertical panels: the icon strip up top, the render window, and a short info panel on the bottom. I accidentally removed the bottom division, the one where samples/max samples is displayed. What is it called? I want to add it back again, and know how to modify the UI - but can't seem to find the name of the panel in question. Thanks for the help!
It is an Application->Status Feedback->octaneRenderForModoLog. Or you can just delete your Modo*.CFG to reset the UI back to default.
Return to “Foundry Modo”
