With Full Scene Reload enabled I'll get two or three frames in and then the render will lock up (Clicking interrupt will then produce a hang of Houdini). Not dependent on any given frame; will render correctly in a different render session (and a different frame will then lock up during that render).
Using latest test build.
A. Windows 10
B. 3 x GTX 980s, 2 x GTX 780s
C. 128 GB RAM
D. Nvidia driver version 382.05
E. Standalone 3.06.1
F. Houdini 3.06.0.5
G. Houdini 16.0.600
Render to disk randomly locking up with Full Scene Reload
C. RAM Capacity (i.e. 6 GB)
Do you have the multithread scene loading option enabled? In this case, try to render the scene disabling it ... in another scene reported some time ago, the plugin had a problem with this feature, that I have not been able to fix yet.
In any case, if you want to send me the scene I could test it here to try to fix the problem using your scene as reference.
