Just a quick feature request.
I really would like better luminance and colour nodes.
In order of importance (#1 being most important):
1) Spline / Curve control for adjusting contrast. The gradient is REALLY clunky for controlling the black and white point of a texture or noise generator etc. It would be so much better if you could use a proper spline by adding points. It would give much more precise control for adding your own curves too.
2) Pivot control for colour corrector contrast. At the moment you can control the contrast of a texture or generator by using the contrast slider but the issue is that the contrast pivot point is fixed. So if you have an image which all the information is in the mid-tones and shadows and you push the contrast slider up, all it does is split the luminance range in the middle and pushes all the information down as there are no highlights to push up. It would be amazing if you could have a second slider which moves where the pivot point is. Please take a look at this link which demonstrates how this works in Davinci Resolve: https://www.youtube.com/watch?v=U8nCDao9IVg
3) Better colour correction controls. I often find myself longing for better colour correction in the node tree to make textures sit more clean within a scene. For example, I might have a leaf texture and I want to create a few variations of these leaves, the only way I can really do that right now is by adding a little bit of colour into the colour channel and adjusting the mix but that never looks natural and always takes away some of the texture's detail. The other method is to use the Hue slider in the color corrector node but swinging the hue is rarely useful as there isn't any way to find the right colour mix and it is incredibly heavy handed. It would be amazing if we could have access to RGB curves for refining colour within the node tree itself. It would be incredibly powerful for not only creating variance on existing textures but also so you can fine tune textures to blend better in the scene. Like if you had a wood floor texture but there is a bit too much red in it for example or if you wanted to refine a skin texture etc. Ultimately if we had an RGB curve (or similar) it would mean we would be able to control the colour not just across the whole image but in the shadows, mids and highlights too
Anyway - I REALLY love what you guys have been doing lately! Some of your recent updates have been amazing and it's great to have bought into a company in which the developers really listen to their customers
Thanks!
Kraig.
