The scene is all octane somehow it stopped working and max is crashing when we try to open it. we have tried with the three latest builds but the same thing happens.
We have to merge the scene in to a new scene every time we want to open it or switch to scanline render in the render dialog before closing/saving.
If we set the renderer to skanline then, it´s ok to open.
This is really a big problem as we have a deadline.
I be happy to send the file, just don´t want to put it up here.
best
Daniel
Scene file can´t open with octane as renderer
C. RAM Capacity (i.e. 6 GB)
- paride4331
Hi dawe,
which Octane 3dsMax plugin version are you using?
You can send me your file or a wetransfer link using private message.
Regards
Paride
Regards
Paride
- paride4331
Hi dawe,
I tested your file, personally I think your issue depends on using general texture node instead of Octane texture node in Octane materials.
Opening the scene with your workaround and fixing Octane materials with proper Octane texture node, the scene seems to work.
Let me hear from you about.
Regards
Paride
Regards
Paride
As it turned out it was a model that had a max displacement modifier on it and a missing tif image when I corrected this, it was ok to load the scene.
I cant tell you what had happened or why. it was one of the sea stars in the scene if you want to check.
//Daniel
//Daniel
