Render Layer pass bug[SOLVED]
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
calus
The separate "Layer Reflections" pass name is wrong, it should not use the _refl suffix, which is already used for the "Reflection" pass.
BUG : Layer Reflection pass overrides the Reflection pass at render time.
Separate passes should just use the user-defined Exr Channel names so these mistakes with the hard-coded names could not happen.
Pascal ANDRE
BK
Hi Calus,
Thank you so much for reporting on this issue. We will resolve the issue in our latest release :)
Kind Regards
bk3d
Return to “Bug Reports”
