Problems with G3f Redspec Shaders
Moderator: BK
MissFergy
Heya ,
I am a huge fan of your shaders and I have many of them . However while trying to render , the ears , and torso are turning grey on application and the lashes solid black. Help please. All other areas seem to be working and I am super frustrated.
Thanks in advance ,
Erin a.k.a MissFergy
abayliss
It sounds to me like some of the maps aren't loading correctly.
Have you tried right clicking on the G3F torso surface under the Octane Materials tab and selecting "Replace all active mats." If this doesn't work, repeat but select "Replace Diffuse mats."
Likewise for the lases, right click on the G3F eyelash surface under the Octane Materials tab and select "Replace all active mats." If this doesn't work, repeat but select "Replace opacity mats."
Sorry, some of the wording may be wrong, because I don't have the client open in front of me at the moment.
Windows 10 Pro 64bit, i7-8700 3.2 GHz, 64GB RAM
2 x RTX 2080ti
You might be better off asking this questions in the dedicated Redspec forum here.
TRRazor
Sorry for being late to this.
The problem you are describing happens, when you're using our shader with an outdated version of the plug-in.
Please make sure to obtain the latest plug-in version here: viewtopic.php?f=44&t=55214
Then try again and let me know how it worked.
Return to “DAZ Studio”
