Reflection become doubled in displacement area (see pict)
CHLT
Hi, can you guys please look at this picture and tell me what you think could cause this?
If I use Octane displacement, my reflection become doubled, blurred. If I use C4D displacement deformer, no problem, but the render take 800% more time.
Any idea what is causing this?
thanks
CHLT
Here the pict link: http://imgur.com/a/GqflD
CHLT
Hi Bepeg4d, no I didnt check. but the mesh is a simple plane... Could you point me how would you check the normals direction? I'm not sure if it would be in C4D mesh menu or in the Octane material...
I will search for it now.
thanks for taking the time to help me!
CHLT
Update: Aligning the normals on the mesh and playing with normal channel dont fix it. However, I've found that if I lower the level of details of the displacement map to 2000x, the problem go away. However my edges are horrible... I need to use 8k to get good enough edges. The gaussian filter is not work at all on lower res... I got tons of small ugly lines in the displacement.
I will try to play with the map itself. Making it real floating 32bit Tiff. Now I use a PNG.
CHLT
Using 32bit Tiff make matter worst:
http://imgur.com/a/Ab7DO
I'm at maximum quality. 8K map, 8K resolution, no filters (they dont change anything).
I can't see linked images. Can you please attach images to your messages? Also attach a sample scene if it's possible.
CHLT
Ok!... the images are working for me here but I will upload them in a wetransfer. I will join a scene too. I cant do it right now but I will upload it today. Thanks!!
CHLT wrote:Ok!... the images are working for me here but I will upload them in a wetransfer. I will join a scene too. I cant do it right now but I will upload it today. Thanks!!
Please don't use external links. No need that. Just use "Upload attachment" button while writing your messages and attach images.
CHLT
Ha! thanks, I did not notice that button before...
Here the best image. You can see the double line in all my displacement. C4D Native give me perfect results with the same sources. Octane give me a doubled reflection whatever the format I use. Now I am using 4k with box blur at 4 to reduce the image doubling while keeping enough details in my displaced edges. At 8K, the edges are better but the reflection is unusable.
Very strange.
