batch Render
JNDesign
hi Faceoff
will there be or is there a way to do batch render in the revit plug in? i.e maybe we can select several views to render unattended?
Also, just updated to V 3 today but it still says v2 on the spash screen
cheers
Hi - you can sort of do this by rendering a walk-thru, but not sure how practical this would actually be. Another workflow you could consider would be to export the scene to ORBX and load it into Octane Standalone. And then activate each Revit View you want to render and Settings->Copy Camera to Clipboard and then paste the camera into Octane Standalone. Create a Rendertarget for each Camera and connect all the other nodes into each of the rendertarget pins. You can then use the Octane Standalone rightclick->Render Job->Batch Render Job to render out each rendertarget. You could create an LUA script to automate the Octane Standalone part.
JNDesign
thanks
Return to “Autodesk Revit”
