Load orbx?
PAQUITO
Is It possible to load an orbx file into modo using the plugin or any other method?
AMD FX8350 8 cores. 16GBs RAM
GTX690
Win8 64.
rrbarb
You can use an ORBX as a proxy assigned to a mesh.
./rrb
Add a Modo Mesh item, make sure it doesn't have Live Geometry Update on, and then load the file via the Browse button under the Proxy Filename. I have uncovered an issue with how this is working, and investigating today, so if you have problems, let me know.
Pauil
Return to “Foundry Modo”
