PCIe Lane issue.
Area for student license holders to post questions and discuss octane.
electric_eric
I've been using one of Amfeltecs external GPU clusters for a couple of years now, see below:
http://amfeltec.com/products/gpu-oriented-cluster/
I've been running 6 x 780ti without issues and lately I decided to upgrade to 6 x 980ti.
I've swapped the cards over to the 980ti's and they power on fine, using the multiple 1000w PSU's. However now I am getting issues with them not being recognised by the pc.
They are not showing up in the device manager and I am getting errors such as 'not enough resources' etc which leads me to think it has something to do with a lack of pcie lanes.
I have a Intel Core i7 6700K Processor which has 16 pcie lanes, which should be enough to cope with 6x 980ti?? Is this enough?
I'm at a loss on what to do to be honest, hence why I'm posting here so any help at all would be really appreciated.
Thanks in advance,
Simon
Intel i7 6700k - 64gb Ram - 6 x 980ti
acc24ex
..your setup should work, I'm interested how you fixed this as I was interested in this expansion setup as well..
- I had a similar problem, but it was due to the riser which didn't have enough power for it to run a 590gtx - but 980ti uses the same amount of power as 780ti - also I ended up loosing connectivity on some pci slots - not sure what happened, but whatever I put into 3 of the 7 slots doesn't get recognised (the board is 5 years old now, maybe just something burned through finally)..
- check the cables, check the pci buses.. plug them in individually into the existing pci-e slots to see if those work find - I know I got a clusterfuck trying to fill all the slots with riser cards - they powered up, but system didn't see them - it was always due to the connectors
- what understood so far, the limitation is that you can plug max of 7 pci devices on some boards.. and it should be up to the motherboard not the cpu
electric_eric
This is the motherboard I have:
http://www.gigabyte.com/Motherboard/GA- ... -rev-10#sp
As I said, this has been working fine with the 780ti's so maybe it is just a case of double checking all the cables.
Maybe I simply have the cards in the wrong configuration and not making the best use of the onboard pcie slots.
Will let you know if I get anywhere with this.
Cheers
acc24ex
yeah, I'm 99% on that it isn't the pci lanes.. also, try adding one by one, to see when it starts failing.. it really looks like it should work by simply switching the cards..
