Hello,
I am new to Octane, I am on an iMac OS X 10.12.4, 3.1 GHz Intel Core i7, 8 GB 1600 MHz DDR3, NVIDIA GeForce GT 750M 1024 MB
While trying to do a test render of a cube I received an error. Below is that error. Is this a matter of not enough GPU?
Started logging on 05.05.17 19:38:07
OctaneRender 3.06 (3060005)
Scene created in plugin version -1
--------------------------- EXPORT LOG ---------------------------
Export materials time= 10.899 ms
Collect objects time= 11.443 ms
Mesh creation time = 17.53 ms.
MB:0/0 ST/MOV:0/1 Nodes:12 Tris:0 DispTris:0 Hairs:0 Meshes:0
VRAM used/free/max:0Kb/0Kb/0Kb Out-of-core used:0Kb total used RAM:5.748Gb
Total export Time = 104.619 ms
CUDA error 2 on device 0: out of memory
-> failed to allocate device memory
device 0: detected an error on render device! trying to recover...
device 0: the device failed immediately after the recovery -> giving up and switching the device into error state
<<< Render failure detected!!! >>>
Please check render statistics to solve the problem.
Device:0 TotMem:1023Mb rtData:2Kb film:0Kb geo:0Kb node:0Kb tex:0Kb unavailable:821Mb
It's about having very low VRAM as you may see in log outputs. You need a better gpu with much more VRAM for working comfortable.
