It seems to me like in the latest build that the Panoramic camera is broken for spherical at least. Downgraded to 3.06.0.4 and everything works fine.
Also, post processing doesn't seem to wrap correctly and creates a seam in 3.06.0.4. You can see an example if you look up and backward here https://roundme.com/tour/143812/view/363535/ The other areas seem to have the problem as well but it's not as noticeable.
Panoramic camera bug
Yes, the panoramic camera has some problems in the latest Octane 3.06 release. They have been reported and will be fixed in the next Standalone and plugins builds.
Anyway, if I'm not wrong, the seams issue with the postprocessing while using the spherical camera is an old Octane limitation that has not been fixed yet.
- lstudios3d
Any chance that post-processing bug gets fixed in the near future?
This issue has been reported several times, and it seems that it has not an easy solution. In this thread, there is a workaround using AE:
viewtopic.php?f=9&t=45237
